So I am remotely connected to a pc where I am running the IsaacSim software (which is computationally demanding at times). Sometimes, during the initialization of the programme TeamViewer disconnects on the remote side with an error message saying "The connection has been lost. Trying to reconnect..."
The remote computer is then unaccessible for an arbitraty period of time (from 3 minutes to 1 hour), and if I try to connect to them TV says "Either your partner isn't connecte to the internet or your partner'sTeamViewer isn't running yet. Please tell your partner to check his/her internet connection or to start TeamViewer". I was wondering if there is ant workaround this becasue it is annoying to have my workflow constantly interrupted due to connectivity issues.
Thank you in advance.
