Raspberry Pi Stuck On Connecting
dalbright
dalbright Posts: 3 ✭✭
edited November 21 in Linux only
I have seen some older posts, none of which really seemed resolved, so I'm going to give it a current shot.
I bought a new Raspberry Pi yesterday, I have connected to it via SSH and set Teamviewer up using the instructions from https://pimylifeup.com/raspberry-pi-teamviewer/
I have added the Teamviewer ID to my Computer & Contacts and it shows as available, and when I power off the Raspberry Pi it shows as unavailable, so that portion is working it seems.
When I try to connect to the Pi, it just says Connecting in the bottom left for several minutes and eventually shows the error in the bottom right of "Connection not established. Authentication Canceled"
Any clue how to fix this?
  • dalbright
    I have tried the following process with no improvement:
    1) run sudo nano /boot/config.txt
    2) Add the following two lines at the bottom of the file:
    Code: Select all
    hdmi_force_hotplug=1
    hdmi_ignore_edid=0xa5000080
    3) Press Ctrl + XY, and Enter
    4) run sudo reboot to restart the RBP
  • dalbright
    Here is the Teamviewer Info output:
     TeamViewer              15.47.3 (DEB)
     TeamViewer ID:            XXXXXXXXXX
     XXXXXXXXXX
     teamviewerd status          ● teamviewerd.service - TeamViewer remote        control daemon
       Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled; preset: e        nabled)
       Active: active (running) since Mon 2023-11-20 23:08:51 EST; 4min 12s ago
      Process: 1116 ExecStart=/opt/teamviewer/tv_bin/teamviewerd -d (code=exited,        status=0/SUCCESS)
      Main PID: 1177 (teamviewerd)
       Tasks: 29 (limit: 8734)
        CPU: 7.587s
       CGroup: /system.slice/teamviewerd.service
           ├─1177 /opt/teamviewer/tv_bin/teamviewerd -d
           └─1931 "" --IPCport 5939
    Nov 20 23:08:51 NESPi1 systemd[1]: Started teamviewerd.service - TeamViewer remo        te control daemon.
    Nov 20 23:10:18 NESPi1 su[1892]: (to admin) root on none
    Nov 20 23:10:18 NESPi1 su[1892]: pam_unix(su-l:session): session opened for user        admin(uid=1000) by (uid=0)
    Nov 20 23:10:18 NESPi1 su[1892]: pam_unix(su-l:session): session closed for user        admin
    Nov 20 23:11:52 NESPi1 su[1933]: (to admin) root on none
    Nov 20 23:11:52 NESPi1 su[1933]: pam_unix(su-l:session): session opened for user        admin(uid=1000) by (uid=0)
    Nov 20 23:11:52 NESPi1 su[1933]: pam_unix(su-l:session): session closed for user        admin
    Nov 20 23:12:14 NESPi1 su[1955]: (to admin) root on none
    Nov 20 23:12:14 NESPi1 su[1955]: pam_unix(su-l:session): session opened for user        admin(uid=1000) by (uid=0)
    Nov 20 23:12:14 NESPi1 su[1955]: pam_unix(su-l:session): session closed for user        admin
