Raspberry Pi Stuck On Connecting
dalbright
dalbright Posts: 3
edited November 2023 in Linux only
I have seen some older posts, none of which really seemed resolved, so I'm going to give it a current shot.
I bought a new Raspberry Pi yesterday, I have connected to it via SSH and set Teamviewer up using the instructions from https://pimylifeup.com/raspberry-pi-teamviewer/
I have added the Teamviewer ID to my Computer & Contacts and it shows as available, and when I power off the Raspberry Pi it shows as unavailable, so that portion is working it seems.
When I try to connect to the Pi, it just says Connecting in the bottom left for several minutes and eventually shows the error in the bottom right of "Connection not established. Authentication Canceled"
Any clue how to fix this?
  • I have tried the following process with no improvement:
    1) run sudo nano /boot/config.txt
    2) Add the following two lines at the bottom of the file:
    Code: Select all
    hdmi_force_hotplug=1
    hdmi_ignore_edid=0xa5000080
    3) Press Ctrl + XY, and Enter
    4) run sudo reboot to restart the RBP
  • Here is the Teamviewer Info output:
     TeamViewer              15.47.3 (DEB)
     TeamViewer ID:            XXXXXXXXXX
     XXXXXXXXXX
     teamviewerd status          ● teamviewerd.service - TeamViewer remote        control daemon
       Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled; preset: e        nabled)
       Active: active (running) since Mon 2023-11-20 23:08:51 EST; 4min 12s ago
      Process: 1116 ExecStart=/opt/teamviewer/tv_bin/teamviewerd -d (code=exited,        status=0/SUCCESS)
      Main PID: 1177 (teamviewerd)
       Tasks: 29 (limit: 8734)
        CPU: 7.587s
       CGroup: /system.slice/teamviewerd.service
           ├─1177 /opt/teamviewer/tv_bin/teamviewerd -d
           └─1931 "" --IPCport 5939
    Nov 20 23:08:51 NESPi1 systemd[1]: Started teamviewerd.service - TeamViewer remo        te control daemon.
    Nov 20 23:10:18 NESPi1 su[1892]: (to admin) root on none
    Nov 20 23:10:18 NESPi1 su[1892]: pam_unix(su-l:session): session opened for user        admin(uid=1000) by (uid=0)
    Nov 20 23:10:18 NESPi1 su[1892]: pam_unix(su-l:session): session closed for user        admin
    Nov 20 23:11:52 NESPi1 su[1933]: (to admin) root on none
    Nov 20 23:11:52 NESPi1 su[1933]: pam_unix(su-l:session): session opened for user        admin(uid=1000) by (uid=0)
    Nov 20 23:11:52 NESPi1 su[1933]: pam_unix(su-l:session): session closed for user        admin
    Nov 20 23:12:14 NESPi1 su[1955]: (to admin) root on none
    Nov 20 23:12:14 NESPi1 su[1955]: pam_unix(su-l:session): session opened for user        admin(uid=1000) by (uid=0)
    Nov 20 23:12:14 NESPi1 su[1955]: pam_unix(su-l:session): session closed for user        admin
  • im getting the same issue it annoying i really need help on this too!
  • I have the same issue, did you find a solution ?
    BTW.... happy new year 2024 😊
  • pleymor
    pleymor Posts: 5
    I got the same issue since I reinstalled raspberry PI OS (Bookworm).
    The only way I found to fix it was to install the Legacy 64bits version (Bullseye).
    Good luck!
  • HorcaDev
    HorcaDev Posts: 4
    Same here! Raspberry Pi works as it should. Teamviewer Host installed (Version 15.49.2 - Date: Dec 13 on Free License).
    I connected this Host with a TeamViewer Management Console. Host is online and is ready to connect. But it's not connecting in the end.
    At the moment, the Raspberry Pi 4 is connected to a hotspot iPhone Network. Not sure if this could be an issue, but the fact that other people have the same issue here since dec23/jan24 appears to be a problem on the part of teamvieler software (client/host).
    I will try the following
    • downgrade the TeamViewer host software
    • connect over an other network source
    There will be also an Maintenance from TeamViewer on 06. Jan 2024 from 20:00 to 23:00 CET. Maybe this help...
  • Kulagin
    Kulagin Posts: 3
    What? What is the solution? I don't understand how those links provide a solution to the problem.
  • MaxDt
    MaxDt Posts: 1
    https://www.geekersdigest.com/how-to-switch-from-wayland-to-x11-in-raspberry-pi/
    In the other thread they link to this to disable wayland, works for me.
    $ sudo raspi-config
    Select A6 Wayland
    Select X11
    ok→finish→reboot
