Raspberry Pi Stuck On Connecting
I have seen some older posts, none of which really seemed resolved, so I'm going to give it a current shot.
I bought a new Raspberry Pi yesterday, I have connected to it via SSH and set Teamviewer up using the instructions from https://pimylifeup.com/raspberry-pi-teamviewer/
I have added the Teamviewer ID to my Computer & Contacts and it shows as available, and when I power off the Raspberry Pi it shows as unavailable, so that portion is working it seems.
When I try to connect to the Pi, it just says Connecting in the bottom left for several minutes and eventually shows the error in the bottom right of "Connection not established. Authentication Canceled"
Any clue how to fix this?
I have tried the following process with no improvement:
1) run sudo nano /boot/config.txt
2) Add the following two lines at the bottom of the file:
Code: Select all
hdmi_force_hotplug=1 hdmi_ignore_edid=0xa5000080
3) Press Ctrl + X, Y, and Enter
4) run sudo reboot to restart the RBP
Here is the Teamviewer Info output:
TeamViewer 15.47.3 (DEB)
TeamViewer ID: XXXXXXXXXX
XXXXXXXXXX
teamviewerd status ● teamviewerd.service - TeamViewer remote control daemon
Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled; preset: e nabled)
Active: active (running) since Mon 2023-11-20 23:08:51 EST; 4min 12s ago
Process: 1116 ExecStart=/opt/teamviewer/tv_bin/teamviewerd -d (code=exited, status=0/SUCCESS)
Main PID: 1177 (teamviewerd)
Tasks: 29 (limit: 8734)
CPU: 7.587s
CGroup: /system.slice/teamviewerd.service
├─1177 /opt/teamviewer/tv_bin/teamviewerd -d
└─1931 "" --IPCport 5939
Nov 20 23:08:51 NESPi1 systemd[1]: Started teamviewerd.service - TeamViewer remo te control daemon.
Nov 20 23:10:18 NESPi1 su[1892]: (to admin) root on none
Nov 20 23:10:18 NESPi1 su[1892]: pam_unix(su-l:session): session opened for user admin(uid=1000) by (uid=0)
Nov 20 23:10:18 NESPi1 su[1892]: pam_unix(su-l:session): session closed for user admin
Nov 20 23:11:52 NESPi1 su[1933]: (to admin) root on none
Nov 20 23:11:52 NESPi1 su[1933]: pam_unix(su-l:session): session opened for user admin(uid=1000) by (uid=0)
Nov 20 23:11:52 NESPi1 su[1933]: pam_unix(su-l:session): session closed for user admin
Nov 20 23:12:14 NESPi1 su[1955]: (to admin) root on none
Nov 20 23:12:14 NESPi1 su[1955]: pam_unix(su-l:session): session opened for user admin(uid=1000) by (uid=0)
Nov 20 23:12:14 NESPi1 su[1955]: pam_unix(su-l:session): session closed for user admin
im getting the same issue it annoying i really need help on this too!
I have the same issue, did you find a solution ?
BTW.... happy new year 2024 😊
I got the same issue since I reinstalled raspberry PI OS (Bookworm).
The only way I found to fix it was to install the Legacy 64bits version (Bullseye).
Good luck!
Same here! Raspberry Pi works as it should. Teamviewer Host installed (Version 15.49.2 - Date: Dec 13 on Free License).
I connected this Host with a TeamViewer Management Console. Host is online and is ready to connect. But it's not connecting in the end.
At the moment, the Raspberry Pi 4 is connected to a hotspot iPhone Network. Not sure if this could be an issue, but the fact that other people have the same issue here since dec23/jan24 appears to be a problem on the part of teamvieler software (client/host).
I will try the following
- downgrade the TeamViewer host software
- connect over an other network source
There will be also an Maintenance from TeamViewer on 06. Jan 2024 from 20:00 to 23:00 CET. Maybe this help...
Hello Guys,
Basically found the solution: Wayland -> Xorg.
See here:
https://www.omglinux.com/raspberry-pi-os-bookworm/
Good luck!
What? What is the solution? I don't understand how those links provide a solution to the problem.
In the other thread they link to this to disable wayland, works for me.
$ sudo raspi-config
Select A6 Wayland
Select X11
ok→finish→reboot0
