Any option to make Lan connection via new interface.
Hello @ui Welcome to our Community and thank you for your first post! 🌏️ On the device that you wish to have the ability to remote into via Lan, you will want to open the application > select the Settings in the bottom left corner > Network > Incoming LAN connections > Select the option from the drop-down menu you deem fit for your purpose.
Let us know how it goes and if you need further help. 👍️
