How do I removed the unnamed devices located in the management console?
Totally agreed with whatever youv've said. However, you can use **Thrid party product** as well.
UmoeMandl - your solution worked for me.Thank you!
Try removing their all records under connection reports. That worked for me.
It looks liks TeamView has no answer for this question. This is disappointing.
