I have just installed TeamViewer Remote on a ChromeBook. When I connect to a Windows II Pro host, I can see and move the cursor, but it does not appear to match to correct place on the host. E.g. if I click on the Start menu, nothing happens. If I right-click an con on the taskbar, the right-click options for the desktop appear.
I have tried using both the built-in touch pad and an external mouse , neither works.
I have tried enabling / disabling the remote cursor - no difference.
Does anyone have any suggestions on how to get the cursor to work correctly?
