Hello and thank you for taking the time to read this.
My mother is in a nursing home and absolutely terrible with technology. I've managed to set up a Android tablet to be controlled by TeamViewer and I can do everything except get through screen lock which I've had to turn off. Using accessibility settings I can turn the tablet off or put it in lock screen but can't unlock it. Is there a way please?
I've tried controlling her old Sony bravia TV but I can't even cast to it so I'm considering upgrading smart TV. I thought I'd try with my current Phillips JX800 series smart TV and although I appear to have set everything up correctly and have control of the TV all I can achieve is to put a blue pointing hand on the screen if it is already set to the app screen. I can't find out anywhere what I should be able to do. Due to disability I can't spend a long time searching but have tried.
Can I :
Switch on and off?
Change volume?
Change Freeview channel?
Open apps?
Access websites?
I appear to need to get permission at the start of each session but this doesn't happen on the tablet is that correct?
Do I need to specific model of Android TV to get good control?
Any answers would be gratefully received
