The latest version of Teamviewer shows my computer screens perfectly on remote control and works well BUT THERE IS NO AUDIO!!!
HELP!!!
Hi beisenbe,
Thanks for your post!
If I understand correctly and you are making connections from the iPad or iPhone, the audio will not be transmitted from any Apple devices as this is one limitation with Apple products.
Apple devices can hear audio transmitted from PC and most mobile devices.
I hope this can be helpful.
Jonathan
Hello beisenbe,
What do you mean that there is no audio? Do you mean that when you try playing on the remote connected PC you do not hear it comeing out of the iPad and iPhone
