after starting Xwindow, the connection to fedora turn off.
i installed teamviewer 12 on linux fedora 20 via command line. running teamviewer service, i can connect to fedora from my windows computer, howerver , after starting xwindow on fedora, the connection is off immediately. do anyone else meat this situation ?
  • ChristianCay
    Hi jason2017,
    If you start X from a CUI TeamViewer is not able to grab the screen. That's why you're having this issue.
    We recommend if you like to use the GUI to start your system the system with it. Switching from CUI to GUI, vice-versa is not supported by TeamViewer.
    Any other questions let me us know.
    Christian
