Greetings,
I started to study networking in general, so I decided to set a wake on Lan function. I've read both the knowledge base article, and the relevant pdf followed all the steps.
I'm using a dell pc, have had enabled the motherboard feature (i had 2 options, Lan only, and Lan with PXE), I've chosen Lan only. Ethernet adapter ipv4 setting check (tried with and without the magic package setting, however, not sure if that's necessary tho), disabled the fast startup, linked Teamviewer to a public address on port 5500, and is linked to my account. The Ethernet controllers static IP is assigned via both its ipv4 preferences and by a rule at the router's admin page. port forwarding is enabled to the desktop's IP on the same port, tried with and without a firewall being turned on.
DDNS: registered an account at no-ip.com, downloaded the IP capture tool, set the correct hostname, the host is up.
After all these, I think it should work, but it's not. I'm having no idea what could go wrong. I'm using TV 13.2.5287 on the desktop, and 13.2.9356 CL android versions. I see the desktop offline on the android device, and I see the power button also, but its dead.
Any ideas?
