I have TV 14 installed on a server with unnatended access enabled, it constantly shows as innactive, however if I connect to it via RDS and login it immediately shows as active in TV, then as soon as I end the session via RDS in becomes innactive in TV again as though the machine is off?
I can connect to it while it is active so the settings are correct.
Any suggestions would be appreciated.
Andrew
