I have what I hope is a fairly obvious question either because there is no solution or there is one that i've overlooked.
Lets say I have a Mac (Mojave) or a PC (Win10) with multiple monitors running teamviewer with unattended access set up. How can I, using a single monitor (Macbook Pro), not have to deal with multiple monitor support. I.e. I would love to only be presented one monitor by teamviewer. I don't want to have to switch between 3 or 4 monitors to see which monitor a program/popup opened up on. When working remotely I'd prefer if everything happened in 'one' monitor for ease of use remotely.
Is that even possible?
Note: I do realize (and have been) that on my Mac Pro with 3 monitors I'm able to go into System Preferences-->Displays and just mirror all 3 monitors so it only gives me one. I would just like that to happen for me and then undo it when i disconnect so i don't need to fix it before disconnecting or when going directly to the PC to use it.
Thanks in advance!
Brian
