I would like to know what settings for O&O ShutUp10 to allow Teamviewer. After using O&O ShutUp10 I discovered Teamviewer runs but won't connect and CPU usage is very high for Teamviewer.
Thanks.
It was under Security then "App access to wireless connections disabled".
