Hi guys,
Today we are seeing recently updated TeamViewer installs saying "TeamViewer Insider Build v. 14.6.2452"
It seems to be a popup with the improvements list, but it says it is running the Insider Build, but it isn't. I can confirm that it isn't using the Insider Build by going to About Teamviewer.
Just thought you should know, I ended up uninstalling the first one before realising it was the popup that was wrong, not the install
