Last I used this was the end of last week and it worked fine, but starting today when I try to connect to my home PC from my work PC it simply doesn't seem to even try to connect. I can sign in on the installed client (v12.0.78313) and see a "Ready To Connect (secure connection)" at the bottom of the screen but in the right pane it shows the login dialog box instead of automatically signing in like it always has.
I have no issue signing in by clicking the button and I see my remote PC's listed, but if I try to connect to one of them it does absolutely nothing visible. Normally it would say "connecting" or something to that effect and open a new window for that remote session. In this case it just sits there as if I did nothing.
I rebooted the system....twice.....with no change. However, I am able to connect without issue from my iOS app to that same system I am unable to connect to from my work PC.
Any help is appreciated.
