I want to uninstall "Endpoint Protection" component, but always failed.
How to uninstall "Endpoint Protection" component?
Thank for helps.
Comment:
OS: Windows 7 64Bit
TeamViewer: 15.3.2682
I can't uninstalled it from windows feature and program
i'm using windows 7 64-bit rightnow
That's old version uninstall method.
How to do that?
Who can tell me?
Thanks & Best Regards.
I had selected Programs and Features from the Control Panel to uninstall Endpoint Protecdtion, but the setup.exe is reinstall one time at backgroud.
At the unisntall processing:
1)Right click to uninstall from the program lists, but the uninstall had no interface.
2)I can see the setup.exe launched from the Task Manager.
3)When I restart my computer, the Endpoint Protection icon has reappear at the right of Desktop,.
It's mean that the unisntall process just reinstall this program one time.
How to do now?
Best Regards & Thanks.
Hi @Hank3518
Thanks for the message. Endpoint Protection or in fact any Remote Management Service can be uninstalled from Windows Programs and Features. The same is for TeamViewer remote control application.
https://support.microsoft.com/en-us/help/4028054/windows-10-repair-or-remove-programs
This below link was old version uninstall method:
https://community.teamviewer.com/t5/Remote-Management-Knowledge-Base/How-to-uninstall-the-TeamViewer-Remote-Management-Services/ta-p/53980#toc-hId--**Please do not post TeamViewer IDs**
I can't find the uninstall method from the new TeamViewer version(15.3.2682).
How to do this?
Help me, please.
Best Regards & Thanks you.
