I also have this problem ... started about a month ago (around 5/1/2020) and was probably due to frequent Windows updatres that were all buggy.
I've actually found a fix to this problem. I went into my router's IP and went and configured it.
Here's what I've done:
You DO NOT need to call your ISP for this fix. It's simple to fix when you know how to enter your router's configuration and reset the router, or either rollback the router's firmware.
This is coming from my experience of fixing the problem. I hope you all are able to fix your internet drop issues.
Any luck with this? I'm running into it as well...
Im having the same issue, whenever i try to connect to a remote pc my internet connection dies. i have to restart the laptop and even sometimes the router. it happens over wifi and/or LAN. i have a fresh win10 install and all drivers updated. Any help will be appreciated.
Still having this problem on some hosts. Any solution?
Was anyone able to find a sloution to this issue?
