1177178180182183413
  • AEH
    AEH Posts: 5
    Hi Sando,
    My last reply on this subject: TV provides you with the right on free use. So, you can't claim this, but you should be able to depend on it. And if I ask three time over by the enduser declaration for reconnection, it's rude or at least unpolite to ignore that costomer.
    Goodwill is an extremely valuable asset for a company and a lot of companies spend much effort and a huge amount of money to maintain their goodwill and/or expand it. I consider it as bad management if my company would drain that expensive goodwill through the back door. Even with non-paying customers. Because these free hitchhikers talk about my company on social media. Recommend my company to family & friends, and to their boss if he needs such software.
    I studied marketing ages ago, in a time that marketing just was born. One of the first lessons was on goodwill as a very precious, but also dangerous comodity if not used properly.
    Hopefully this community messages will be read occasionally by some VT manager and hopefully he/she will pick up this clue.
    Thanks for sharing your thougths , have a nice day and stay safe !
    AEH
  • Bebbspoke
    Bebbspoke Posts: 22 ✭✭
    Hi SandoHP... It would seem I've opened a can of worms!
    I am not aware as to whether you are a TV employee or a privateer... but it's quite apparent that you are effectively "on their side"....
    I too would support TV - I have been a privatw "free" user for several years with only a few issues over the period... but here is the major hassle; -
    You quite rightly state "but if nobody files a bug report through the proper channels it will never be corrected." - but if one is UNABLE to use the "proper channels" - because of a bug in the TV website programing...
    Then how else can the free user report the fault???
  • Fiona_G
    Fiona_G Posts: 689 Staff member 🤠
    Hi @Ady and @mr-b,
    We are sorry to hear about the issue you were experiencing.
    I just tried the step of Generate PDF and it seemed worked from our side. Could you please try again?
    If the error continues, please kindly provide the screenshot to help us to investigate further.
    Kind regards,
    Fiona
    Fiona_G
  • Olgayl
    Olgayl Posts: 1
    Hello.
    When I try to connect to teamviewer, I get a message about suspected commercial use. I only use teamviewer for personal purposes. This usually happens when I go out of town and the computer stays in my city apartment. Now when I try to connect to the computer from an Android smartphone I see a message: "Commercial use. Connection is blocked due to exceeding the time limit."
    What should I do to unblock teamviewer? I don't use it for commercial purposes.
  • Strech
    Strech Posts: 1
    When I try to connect from my telephone to laptop, I have just 1-2 minutes, then I see this screen:Screenshot_20200817-103808_TeamViewer.jpg
    Commercial usage. Connection is blocked. But I just connect for playing lineage, it is not commercial use.
    What should I do?
  • AriannaMicrochi
    same thing for me
  • asofus
    asofus Posts: 1
    here happens the same, and is for personal use... nothing of professional use... :(
  • Bonzadog
    Bonzadog Posts: 28 ✭✭
    @TeamViewer Looking at all the numerous entries in the Community regarding non-commercial use, I feel that TV must either improve the Algorithm that determine whether the usage is commercial or not OR drop that and charge a small free for non-commercial users. But the current situation is causing a lot of bad PR for you.
  • Edira
    Edira Posts: 1
    I have free version, use non-commercial. I use only to help my father, only contact with one ID. The system tell me that I use for commercial. What can I do?
    Can you help pe me?
    @Bonzadog wrote:
    @TeamViewerLooking at all the numerous entries in the Community regarding non-commercial use, I feel that TV must either improve the Algorithm that determine whether the usage is commercial or not OR drop that and charge a small free for non-commercial users. But the current situation is causing a lot of bad PR for you.
  • Bonzadog
    Hi, Annoying theis non-commercial business. You have to now fill this form https://www.teamviewer.com/reset/ They say seven days but in my experience it may well take more than the seven days TV says it will take Good luck.... BD
  • Thw0rted
    Thw0rted Posts: 14 ✭✭
    I posted a few pages back that I used the reset form to request a reset.  I just wanted to say that, a week or so ago, I stopped getting the "commercial use" warning on the PC in question.  As far as I can tell, I never got an email or anything, it just started to work.  I thought if anybody was sitting around, not using TV because they assumed it was still broken, you might like to know that they may fix it without notifying you.
    To those who say the reset form isn't working: one user said that removing spaces from their Teamviewer ID fixed it.  (I agree, they should have a place to report bugs in their website.)
    To those who keep posting "HOW DO I FIX THIS" (and usually a 5-paragraph life-story along with it) without reading even a handful of preceding posts: before you post, read at least a tiny bit of this thread -- the pinned answer on the first page is currently correct!  Making this already-enormous thread even longer without adding any useful information helps no one.
    ETA: I just noticed from my email notifications, it looks like a lot of people are starting new threads, then the forum mods are merging theirs into this one.  Hopefully, those people are going back and reading the pinned answer.
  • arruga
    arruga Posts: 2
    TV support team confirmed by email to me that account was reset to free, but as sooon as I sign in, I immediately  I get the  "trial version" and the "expired" message, before even attempting to connect to any machine. It's as though my account is frozen in the "trial expired" state and the reset you mentioned hasn't taken place. Can't use it. Pleae help unlock it
  • mr-b
    mr-b Posts: 6
    In the end I used the alternate form to submit my TV ids online and they have now been reset. From another thread it turns out the form button issue may be with UK postcodes not being recognised. :-(
  • glazooh
    glazooh Posts: 1
    @JaneT14 wrote:
    I had the same problem with the system hanging at create pdf, discovered it was the "space" in the post code ie: "XX11 7PP" needs to be "XX117PP" - no space. It created the pdf, then you save it to your device and upload it.
    Yes, took me ages to realise that the US software didn't like the space in the UK postcode, once removed the .pdf went off quite happily. That was 6 days ago and I still can't use it.
    They now say '7 business days' to respond - the best part of 2 weeks which is ridiculous, I just googled and ran one of the fixes to delete all the stuff in Windows and now works fine again.
  • Goldenbouncer
    Goldenbouncer Posts: 4 ✭✭
    I use TeamViewer for private use and not commercial I have called and fill out the form but it will not generate pdf for me to send hope someone can help me
  • Bebbspoke
    Hi Goldenbouncer - if, as I assume, you're from the UK - the reason that it will not generate a .pdf is there is a bug in the Teamviewer "report" software.
    To resolve your issue; - please note that when you fill in your "postcode" you should enter such as one CONTINUOUS string - i.e (say) your postcode is N23 3RZ it must be entered as N233RZ
    without the space.
  • bazbsg
    bazbsg Posts: 112 ✭✭
    This is one of my website pet peeves. They shouldn't bother checking the postal code if they don't know the rules for the postal code. This affected me when I lived in Singapore which has six digit postal codes and in the Philippines which has four digit postal codes. Many web sites insist on five digits.
  • homersolly
    Apologies if I'm in the wrong location, but this is my first posting.
    I have used the Teamviewer Free version for many years with no issues at all to link into my personal server at home when I am at work (not work related at all).
    This morning I am being informed that I am using it for Commercial use & it links me in for any about 1 minute.
    Is this becuase I am using it from work & if so, why has this started after numerous years of connecting from work to my homer server?
    Thanks in advance for any help given.
    Kev Solly
  • TotalPC
    TotalPC Posts: 87 ⭐Star⭐
    Hi @homersolly ,
    Information regarding your issue can be found at the beginning of the discussion here.
    In it there is information about falsely being identified as a commercial user and if that's the case you can request a reset using the links provided. The reason it has only just happened is because TeamViewer uses algorithms that does it's best to separate personal use from commercial use and you must have only just now hit that threshold.
    TeamViewer user since version 6 (2010). We used other remote software programs (TVNC UVNC PCAny) for many years before.
  • DerrickJones
    Totally agree with the opinion of the reset submit form. Did the remove space thing since I've worked in software development and this, alongside apostrophes in address fields *used* to be a big stumbling block in ***1996-2004*** when I was in that field. Surely things have improved since then!
    Thing is, I don't wish to wait 7 days to help my aged mother with her computer problem so that TeamViewer can reset their incorrectly set commercial flag. I got in the car and drove to her house. Since, funnily enough, she's MY MOTHER!
    TV is a luxury at the end of the day, but not one I'm prepared to fork out a load of cash per month JUST IN CASE my Mum needs help. I am not getting rewarded (other than the love of my Mother!) for helping her, so I'm using the software as TV proudly states it want it to be used.
    Well, it's been a week now, will give it another seven days, and if I receive no e-mail, I'll just uninstall and do the drive thing. My brother who lives in Spain, however, will just have to help himself......
    Derrick
  • DerrickJones
    Sorry, read response a day earlier, which said the same....
    As a UK user, I tried to do the reset form the other day - the code behind the form is expecting no spaces in "Zip Code" field - and throws a highlighted field response. It is expecting all numbers, according to the descriptive text
    This is despite in the UK (or as TV list it, United Kingdom of Great Britain & Northern Ireland), our version of "zip code" is "Post Code", and these, by default have a space between the two sections. Postal Town and Locality. E.G. "WA1 1AB" is a general PostCode format.
    Removing the space allows the POST to complete. However, despite being told to wait 2 business days, I'm still not updated even after a week. Quite shocking.
  • Felipecha07
    Same here, I need it to help my grandmother in another city, and I am not getting it!!!! Says that the connection will end in 5 minutes, but closes in 10 seconds!!
    Hello @DDT2005
    Please try the procedure from a different browser.
    I hope this could help. ?
    Best regards
  • ellnic
    ellnic Posts: 1
    Hello
    I hope you are all keeping well.
    I want to start by saying that I have been using Team Viewer for years and I am very grateful that you provide the free tier.
    This has been an ongoing issue - every 6 months or so TV flags my use as commercial. I fill out the form and within about a week I get an email saying I have been reset to 'free'. I have never been able to ascertain why this happened, and no explanation was ever given.
    Just recently, this happened again. Ok, this again... filled out the form, sent it off. Except this time I got an email back saying that they could not be certain I was not using this commercially, and that I could either buy a license or fill out a form. I filled out the form and emailed it off. I am still waiting to hear anything, and I am still unable to use TV.
    Prior to signing the form, I read and re-read the free use policies to make sure I am adhering to them, and I believe that I am. So far as I can tell:
    1. No use commercially - to / from a business
    2. No use on 'Server' operating systems - as in a OS designed and marketed for serving
    3. No paid use
    Well, I checked all my machines again, and my use is this:
    1. Win 10 machines for friends and family
    2. Win 10 / Mac / Linux personal machines
    3. Personal phones / tablets
    4. Linux machines running media servers - which I have read on various threads is ALLOWED, they are Client OS with a media server app - I help 3 family members with their boxes - non-business use and also have my own
    5. All to/from IPs are residential
    There was one recent addition, which I think 'may' have caused the problem, but it's a really grey area:
    6. A virtualisation box for dockers - It's a Debian Linux box with a custom PVE kernel. It's not technically a server OS, and is not used commercially. It's a home setup, plain and simple. The PVE kernel just makes my life easier for ZFS that is all.
    For number 6: Is this the cause of the problem? It's not a Server OS (Proxmox itself would be, but this is a custom setup), it's not being used commercially.
    Just to be sure, I have uninstalled TV on that machine, as I have no intention of breaking the use policy. If using a custom kernel has triggered this, then I will not make that mistake again. However, I would now like to be reset to free because £32/month for personal use is not something I am prepared to do. At worst this is either a misunderstanding of the policy, or a detection error. There has been no deliberate deception or attempt at circumvention here.
    Is there any chance of this being reset to free now the possible offending machine has been removed? Any help or clarification would be appreciated.
  • monesy1
    monesy1 Posts: 2
    If team viewer is free for personal use.  Why was I kicked off from getting on my 90 year old moms computer.  Now I can't help her.  I was told I used my free time.  Is it limited time use?  I am not a company, just helping an old lady or trying to.  Suggestions please.
  • TheBroook
    I currently have 2 types of TeamViewer accounts - one paid/commercial license and one free/private use accounts.  The private use account has detected "commercial use" and i think thats because i may have logged into one of the commercial PC's accidentally.  I sent in a reset ticket last week (Monday 17th), to which no one has responded yet.  Can anyone help reset on this forum?
    Kind regards,
    Mike
  • pierodicarlo
    I submitted a ticket requesting the unlocking of some IDs from my account for Free Version at www.teamviewer.com/reset, but I forgot an ID, that of my iOS App. Problem is that it's 12 days and the site still says
    "Your request has already been submitted and is pending further review. Thank you for your patience as we process your request."
    I need to add the other ID that is still deceptively blocked.
  • auriclux
    auriclux Posts: 1
    This is all I know.
  • monesy1
    monesy1 Posts: 2
    I was kicked off for suspected commercial use.  I only use Team Viewer to help my 90 year old mother on her computer.  After requesting reactivation because I am a personal user only.  I was reactivated.  Now, I cannot connect to my mother's computer.  I get a gray screen just like after I got kicked off.  I can't see anything on her side.  What do I do?
  • Thw0rted
    Derrick, just so you know, after I submitted my form, I never got emailed when they reset my flagged computer.  It just started working one day.  So, check every now and again, and you might be surprised.
