As the title details, the latest version from the teamviewer yum repository is not digitally signed.Affected package version:teamviewer-15.9.4-0.x86_64As of writing this will break package updates on client machines.
Hi @Jack_Greiner
Thank you for the info!
I talked with our Linux team and they told me they are already on it and will provide a new RPM package soonest ?
Cheers,
Esther
Hi @GFORCE1
I quickly checked with the team and they told me, that the fixed version is already available on our website: Download for Linux
Also, they activated the auto-update, BUT if you received the auto-update before, you will need to download the new version once again as the auto update won´t work a second time.
EDIT: The recommendation from our Linux team is to get the package from the website.
I´ll post that info also in the Change Log.
Thanks and best,
Hi @Esther ,Any clue when new version will be online ?Regards
I set gpg check to 0 in my /etc/yum.repos.d/teamviewer.repo file for now. I made a script to change it back in a week in my cron job. Oddly, my DEB based systems using APT do not seem to be effected.
For now, I just disabled the repository from Gnome's Software Center
