can't connect to the company
the problem just as the photo showsthe problem just as the photo shows
  • Fiona_G
    Fiona_G Posts: 689 Staff member 🤠
    Hi @Mffff666,
    Thank you for your message and welcome to our community.
    Your screenshot shows that your TeamViewer indicates a red light and requests to check your connection. There are a few things you can check as in this article.
    I hope the information would be helpful.
    Kind regards,
    Fiona
    Fiona_G
  • Mffff666
    Thank you for your reply.
    Firstly, I confrim that my internet connection works well.
    Secondly, I try to open all the TCP ports which are advised to.
    Thirdly, just yesterday afternoon I still could connect to another device. However, after an exit, whatever I did and whichever ID I input, It just showed me you can't connect to the company and It even did not have the screen for password.
    I suspected  if there had some problem with my ID.So I send an email to reset my ID for free and It informed me my ID has been reseted just now. But when I  login to check the ID, It did not change.
    Additionally, I have run the TeamViewer_checkout and it create a zip document.How can I submit it?
    I really need to figure out this problem in order to restart my work.
    Hoping for you reply soon!
This Week's Leaders
