My access has been working fine and suddenly I get this message.
I've switched my router on & off as this has worked in the past but not this time.
No other internet issues
Not had any Windows updates recently.
Help!
I have been informed that all our systems are back online and functional.
Thanks for your patience,
Esther
Thank you for your reports so far!
We immediately gave all info to the devs.
Let´s hope it´s all resolved now. You can keep track of the status here: https://status.teamviewer.com/
Best, Esther
Yep, back online again!
Thanks Guys & Girls!
Roy
It's ok for me now
Google DNS (and perhaps others) can't resolve Teamviewer DNS.
C:\Users\user>nslookup router10.teamviewer.com 8.8.8.8Server: dns.googleAddress: 8.8.8.8
*** dns.google can't find router10.teamviewer.com: Server failed
same result from https://toolbox.googleapps.com/apps/dig/#A/
me too....
Hello Esther,
I am in Essex in the UK, and we have issues, our client is in Telford in the UK, they also have issues, exactly as @josmith447 described.
But, it seems that established connections are fine, just new connections, don't authenticate with your servers.
Hope that helps.
Hi
Manchester M46
Just saw your connectivity issue message so I'm guessing that's related
Hi @josmith447
Thanks for your report!
Where are you located?
Thanks,
