TeamViewer builds for aarch64/arm64?
MaltronCraft
MaltronCraft Posts: 2
edited December 2020 in Linux only
Hello, I am trying to get my Raspberry Pi 4 setup with TeamViewer.
My Pi is running Ubuntu Desktop 20.10 64-bit (64-bit is the only option for Ubuntu Desktop) but I can't start TeamViewer Host. It fails because it detects aarch64. I've tried many different things, including the non-arm builds for Linux.
If anyone can assist me and any other Raspberry Pi 4 users who run Ubuntu Desktop, please reply to this question.
Thanks! and Merry Christmas to anyone who sees this on 12-25-2020 :)
  • CRhamilton
    CRhamilton Posts: 2
    edited January 2021
    To add arm32 bit to the rchitecture use.
    sudo dpkg --add-architecture armhf
    sudo apt-get update
    sudo apt-get upgrade
    sudo apt-get -f install
    sudo apt-get install libxtst6:armhf
    Then you should be able to install the armhf version.
    This should make it work.
  • zBugi
    zBugi Posts: 2
    I did it but i still got an issue when i do sudo teamviewer setup
    The framebuffer console seems to be unavailable or has the wrong format. For connections to framebuffer consoles to work please make sure that /dev/fb0 is accessible and configured to at least 16-bit depth.
    $ cat /etc/default/grub
    GRUB_GFXMODE=1024x768x32
    GRUB_GFXPAYLOAD_LINUX=keep
    $ sudo grub-mkconfig -o /boot/grub/grub.cfg
    $ sudo reboot
    after that i get an authentification error and then teamviewer says Connecting... like forever.
    When I run
    $ sudo teamviewer setup
    again the same issue appears
