When I disconnect from a paid remote session, it thanks for me using the free version.
JillSuttenberg
JillSuttenberg Posts: 4 ✭✭
edited May 2023 in Licensing
  • JillSuttenberg
    How come it doesn't recognize that I have a paid account
  • Yuri_T
    Hi @JillSuttenberg,
    Thank you for your post 😌
    It does not seem that your account has been linked to your account.
    In order to use your license please make sure that you have activated your license first: https://community.teamviewer.com/English/kb/articles/4326-how-to-activate-your-license
    Hope this information will be helpful.
    Yuri
  • JillSuttenberg
    Well, that didn't work well. I tried following the instructions. I had no email telling me to activate. I found one telling me to get started. I tried that. I then had to sign in. It tells me my password/email is not recognized. I clicked forgot password even though I just changed it three weeks ago. It tells me to try to connect to my own computer, but no where does it allow me to change the password.
    I tried again. It tells me my license is not valid.
    Any other thoughts?
  • Yuri_T
    Hi @JillSuttenberg,
    That is very odd.
    On our system, it looks like you successfully activated using the activation link (Which is indeed labeled "get me started") shortly after my earlier response, about 5 hours ago.
    By all accounts, you should simply just need to sign into the software, confirm that it says "Business" beneath your name in the top right-hand corner and you're all set to go.
    If you are still getting a "Trial" message, can you send me a screenshot showing yourself signed in with the message so I can help you figure out why this is not working for you?
    Yuri
  • JillSuttenberg
    I just used a "free" remote session.
    See screenshot attached.
