How do I check my license subscription status?
Where to check my license subscription status like when expiry?
Thank you.
Jeffrey
    Hello @PentaMIS,
    You can check it directly in the TeamViewer client under Help ➜ About TeamViewer
  • PentaMIS
    PentaMIS Posts: 7 ✭✭
    edited February 2021
    Hi JeanK,
    Thanks for the replied.
    I'm using the latest version and got this.
    @PentaMIS Alternatively, you can check your invoice. The expiration date is indicated there.
    Also, if you have activated your Customer Portal, you may check there as well as all the license information is also available.
  • PentaMIS
    Hi @JeanK,
    I tried to login to the Customer Portal and this is what I get.
    Any idea how to go about from here?
    Thank you.
    Jeffrey
