Failed connection...
TWackel
TWackel Posts: 3 ✭✭
frequently getting this message when trying to access my iMac remotely from my MBAir - any advice would be greatly appreciated!
    Hello @TWackel,
    This message indicates that TeamViewer lost the connection to our master server.
    I recommend you to restart TeamViewer on the affected devices.
  • TWackel
    TWackel Posts: 3 ✭✭
    Thanks for the tip - I've tried that multiple times with no success =(
    It seems that if the Mac I'm trying to access has gone asleep - then I can't access it
    I have enabled "Wake for Network Access" in the power settings - but again no luck
    I also found this doc online https://dl.teamviewer.com/docs/en/TeamViewer-Manual-Wake-on-LAN-en.pdf but it appears to be dated as some of the references are no longer available
    Thanks in advance for any suggestions you might have
