1221222224226227413
  • redskam
    redskam Posts: 0
    Hello I have a similar problem : I have been using team viewer successfully for less than a year and ever since a few days ago I am unable to connect more than a minute on my remote laptop. Everytime I do, it disconnect me and block me from reconnecting saying "Connection blocked after expiration of response delay
    Your licence limit the maximum time of session with a partner, immediate reconnections are blocked. Please try later or update your licence.
    Connection to this partner blocked until 15:36 (in one minute)"
    It's always been working fine, why does it suddently do this ? Was there an update ?
  • pauluspla
    pauluspla Posts: 6 ✭✭
    edited March 2021
    Yes, I got more or less the same message. In Spanish, but very similar.
    More info shows a message thanking for your buy, and that my account is being upgraded to business(something that I haven’t done)
  • Esther
    Are you all logged in to your licensed account? Are you all using TeamViewer for HomeOffice or Smartworking?
  • redskam
    redskam Posts: 0
    I use the free version of TeamViewer (I don't know if it's the HomeOffice version?), since I only use teamviewer to connect on my laptop and nothing else
  • Esther
    Thanks for your feedback @redskam ! If you use it for connecting to your work laptop, you need to buy a license.
    If you do not use TeamViewer for anything related to anything commercial, you can fill out the reset form here:
  • RafRaf
    RafRaf Posts: 1
    I'm using teamviewer in its free version to mostly to support technical issues to my father.
    recently after I remoter his machine it keep throwing me out due to timeout sessions (after 10-20 seconds)
    and when i'm trying to connect again i get the message that the conncecton is blocked.
    I just started to get this issue and it was always working great.
    I'd appreciate if someone could tell me how to resolve this issue.
    Best regards.
    Rafraf
  • Wanderer999
    Wanderer999 Posts: 1
    I use teamviewer for few years to access serveral computers. Til now it works perfect. I have the same problems as above. Sessions won't start. Sometimes it makes connection for 30 seconds, i can't do anything. A large mouese pointer appaers, but i can't do anything and session stops.
    All my computers have the same problem. I have a free license a lot off years.
    Henri
  • filipravn
    filipravn Posts: 3 ✭✭
    I get logged out of my remote session after 1 min, as teamviewer claims that I am using my private account for buisness. I solomnly declare that I don´t use it for commercial or business related access, hence I would like to get my private access account back as I used to have it.
    There seems to be no option to contact Teamviewer support than writing via this page, so Im very stuck unless I want to pay for business license which is not at all relevant for me.
  • pauluspla
    It seems to be a quite common problem recently, as I see in other threads. It doesn't seems to be a problem of commercial use of Teamviewer, but a problem in Teamviewer side. I hope it will be solved soon
    And I wonder... in order to avoid this problem, I wouldn't mind to pay for an account... but the cheapest option I find cost 430€, a "little" too much for control only one phone. It is cheaper for me to buy a new phone that is compatible with Airdroid. There is a cheaper one, but it seems for computer, that I don't need.
    Isn't there any other option?
  • pauluspla
    I have also this problem, in Spain.
  • Cátia_C01
    Cátia_C01 Posts: 2 ✭✭
    Same problem here in Portugal.
    I've already submitted the request to restore the connection, but so far no reply whatsoever.
  • galpesha
    galpesha Posts: 1
    I am a private user only. Why I have a time limit?
  • Fabio70_tecnico
    Fabio70_tecnico Posts: 4 ✭✭
    Thanks Ester, but I have always used non-commercial license as I offer a service to friends and relatives .... so I have no license.
  • dfyzdfy
    dfyzdfy Posts: 1
    I have a limited time, but I only use TV for non-commercial purposes.
  • Bikuler
    Bikuler Posts: 0
    Same here in Germany, ridiculous
    Mac with Catalina
  • Madman227
    Madman227 Posts: 12 ✭✭
    I have decided to move on, thanks for the years I managed to use TV. The algorythm is faulty and people are being hurt by this, I only use it in a local network between a laptop and a main pc. I have it on another that I only login to update and keep it closed. I had once sent the form signed, sent it again and nothing changed. Because of this I found something better and faster than TV to use on my local connection. I hope they listen to people more.
  • davidinf23
    davidinf23 Posts: 0
    I have the same problem in Italy. Does anyone have any idea how to solve it? Thanks
  • Sixx
    Sixx Posts: 0
    I have been using TeamViewer for years. I use it to connect to my own computer from my phone or laptop. A couple days ago I got the message about commercial use suspected and my connection was limited. I mean, I don't even have a job! I use it for personal use, and not even for familiars, but just to my own computer. I have it installed on my other computers, as I have 2 computers and two laptops I sometimes still use, but I don't connect to them much as they're old. Once every some months if at all.
    I don't really understand why I got this message. I don't work or something like that, I just connect to my computer to use it because I can't stay physically in the same room my computer is due to health issues. So I connect to it by phone or a MacBook laptop.
  • Piotr78
    Piotr78 Posts: 1
  • elbutchos
    elbutchos Posts: 1
    Hi guys,
    I'm kind of new here. I'm using TeamViewer rarely to support my family ( which are not too tech savvy ) on PC matters. It now seems I get kicked out of the session after 1 minute or so and cannot reconnect anymore.
    It sais " your license limits the maximum siession duration to a partner ..... ".
    I've been stumbling around on the site to actually open a ticket but I cannot find anything.
    So how can I actually open a ticket ? Could you guys please give me a link ?
    Thank you in advance.
  • Francolujs
    I've been using for personal account for several time but now I had my account blocked because of commercial use which is not true.
    What should I do to retrieve the personal use available again?
  • CarlosGS
    CarlosGS Posts: 0
    Me too
  • Hong1234
    Hong1234 Posts: 1
    I am on a free license for personal use and I can not remote control my other pc for longer then 1 or 2 minutes and then I get the session timeout pop up and get disconnected and I can not connect again for like 3 minutes. What is going on?
  • crithomas1
    crithomas1 Posts: 0
    I have exactly the same problem but in the french version
    so I got "le délai imparti à la session a été dépassé"
    maybe its a manner to transform potential future teamviewer clients in teamviewer haters ? yin an yang ?
    Seriously guys, you shouldn't do this !
  • petje
    petje Posts: 0
    I have a free account and using teamviewer for privat
    Teamviewer will connect to another computer, but the connection fails after a few seconds/minutes :
    This was a free session
    when i wanna re-connect ,i can't and get the message that my connection is blocked for a few minutes
  • clorinthe
    clorinthe Posts: 3 ✭✭
    I Guess this Maintenance
    is intended to fix the problem below (wrong reporting of Past Incidents)
  • Baltix
    Baltix Posts: 3 ✭✭
    Since 3 days I have exactly the same problem. If you will get answer from TeamViewer support, can you contact me too, please.
    Bests regards,
    Baltix
  • markad
    markad Posts: 3 ✭✭
    edited March 2021
    I sent the reset management form to TV and they got back to me this morning stating that they had reset my TeamViewer.
    Just checked it out and the problem has been fixed, for me anyway. Mind you, I also had the scheduled maintenance thingy, too.
    Thanks to the TeamViewer team...
  • ernestodo
    ernestodo Posts: 0
    it is happening to me aswell... it says it detected i am not a home user, and that i am a commercial user (which i am not). i will leave teamviewer if not replied soon by tech support.
