Teamviewer Host Registry Edit
We have created a MSI installed for our host installs. We are trying to change the Advanced Options then Access Control "Show confirmation" to the new setting of "Generate new"
We are not able to find where we can change the registry edit to make this change?
We think its located here but we have changed it from 0 to 1 and still its not changing properly on our host.
[HKEY_LOCAL_MACHINE\SOFTWARE\TeamViewer\DefaultSettings\MsgBoxDontShow]
"PasswordOnSessionEnd"=dword:00000000
Did you end up finding a solution for this one?
I imported the registry and can see these policies are HKCU\ but even if I import them manually it doesn't change anything.
I figured it out....
[HKEY_CURRENT_USER\SOFTWARE\TeamViewer]
"ChangeDynamicPassword"=dword:00000001
Cannot be made to a local registry from what I can tell.
GPO it out imo.
Hi randizzle and willsie:as
i am having the same issue. I can not change it by using the SETTINGSFILE Parameter in the *bat file used for deploy.
Did you finally manage to make it work?
try this location:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\TeamViewer
and not:
afer you import the reg key, run 2 command:
net stop teamviewer
net start teamviewer
It should work.
Thanks @SAComputers but it doesn´t work...
In fact I´ve generated a tvopt with the right configuration
[HKEY_CURRENT_USER\SOFTWARE\TeamViewer\MsgBoxDontShow]
"PasswordOnSessionEnd"=dword:00000001
i run this simple command line
msiexec.exe /i "%~dp0TeamViewer_Host.msi" /qb SETTINGSFILE="C:\Users\Supervisor\Desktop\TeamViewer MSI\Host_Settings.tvopt"
and the parameter is not change as the registry editor variable is not changed from 0 to 1
Any idea?
Same here with TeamViewer Host 15.44.6.
I can enter the registry values "ChangeDynamicPassword"=dword:00000001 in "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\TeamViewer" and "HKEY_LOCAL_MACHINE\SOFTWARE\TeamViewer" - as well as "PasswordOnSessionEnd"=dword:00000001 into \MsgBoxDontShow.
But if I open the GUI, the "Random password after each session" keeps unchanged. I've removed all the unused registry values and restarted the TeamViewer service. No luck.
Any idea?
