Remote access without hitting “access”
AndreaRova
AndreaRova Posts: 1
Hi everyone. I’m having problems remote controlling a Motorola Smartphone from a PC without anyone hitting accept on the Android side using host or quick connect... every time I connect I need to be near the smartphone and manually press “allow”. Is there any way to automatically allow it?
Thank you in advance to anyone who will help me out!
    Hello @AndreaRova,
    TeamViewer QuickSupport has been designed for attended access. Threfore, a confirmation is required by the remote user.
    TeamViewer Host has been designed for unattended access. Threfore, no confirmation is required on the remote device.
  • AndreaRova
    AndreaRova Posts: 1
    @JeanK
    im using Host, but everytime I connect from the PC, I still need to press “allow” on the smartphone app. Can you help me out? I tried everything without any success.
  • ScottMcM
    ScottMcM Posts: 0
    This started happening with Android 10. I have the same issue trying to use Host app to remote control a phone. Was hoping it had been solved by now.....
    Thank you for your feedback @AndreaRova and @ScottMcM
    Could you please send me via private message the logs of your mobile devices affected by this issue?
  • ScottMcM
    ScottMcM Posts: 0
    JeanK,
    Happy to but it will take me a few days since the phone in question is literally very remote right now and I won't be able to get to it for a while. Thanks!
  • Glenni
    Glenni Posts: 1
    edited July 2021
    Must be close to telephone because I have to hit START at the phone. See picture. How can I proceed for unattended access? It is a Huawei p20 pro phone. (Android 10).
    best regards Glenni
  • Lou_Laptop
    Lou_Laptop Posts: 2 ✭✭
    I have the same problem and have not been able to find a fix.
