This just started happening so I rebooted both my home PC's and curious why it is happening?
I am not getting the flag that i am using it for corporate use, it just diconnects
I'm using the free version and cannot seem to hold a connection for more than 30 seconds at a time. I then get kicked out stating I can reconnect in 1 minute but it never works until hours later.
This is not for commercial use and is mainly used to remote into my friends / family PCs for very short amounts of time.
Any suggestions?
Connections are failing right away, I think it started happening today 4/20/21 . It says block till a time and even after that time the same message with another time.
I amhaving the same problem. I cant imagine why
Even after the blocked until time it does not work, repeats the same error and a later time
Getting the same error. Please help...
Same issue.
I keep getting booted out of my sessions with the licensing message as seen in many posts above. I try to reconnect after a couple minutes, and the time it will be blocked until just keeps moving up. This is annoying. Can't even find any way to contact teamviewer support to resolve this
I have a free version and every time I want to connect with another partner only gives me a few minutes, then it logs out from the system.
@Garjion @TeamViewer - I tried that just now and I get the same result: a timeout and my sessions close. I am giving it until tomorrow AM and then I am switching to "Third party product" or other tool. This is disappointing...
I am having the same exact issue.....I assist my grandmother with various legal issues on her computer and then all of a sudden today I receive this error....everytime I attempt to connect it kicks me out......any suggestions???
I received the same message every time I want to log in and also received a lot of e-mails every minute. I don't know how can I stop this.
A year ago I signed a paper and sent it back to Teamviewer that I did not use it commercially and they let me back in without timing out or getting the commercial use warning..
It seems every time I change my home network at all - even just get a new modem or add a router - I get timed out. That's where it is now despite my previous letter. Even double natting seems to over excite their method of detecting commercial se.
This is the same problem I am having with my Mom, she is in a assisted living home and she limited visitor access. I have no access. I do not use TeamViewer commercially, this program is how I can keep her computer up to date or help her with an issue if she encounters one. I would like to know how to fix this so I can continue to help her.
Where do I send this letter, to have this situation fixed.
Thank you so very much.
Hi
I use TeamViewer to manage my mother's laptop. But teamviewer claim to have detected commercial usage and have limited sessions to 57s, which is useless. Is there any way to get back to domestic use?
Morning all
I use a VPN on my pc and connect to it on my phone/laptop and I continue getting a message saying I’m using the program commercial and blocks me
What dose it means "commercial usage"?
@Moonshot72 when you uninstalled it did you delete the registry files, and the files in %temp% and %appdata%?
I was helping my mother again... not some corporate **bleep**... **bleep** THIS... warn me... ban me... whatever... i'm done with this **bleep** software... it the millionth time it happens. Also, whenever i try at the time it says in that **bleep** window, it just adds a minute, tried at 12:43 and it popped with 12:44... and so on, **bleep**... SO **bleep** THIS SOFTWARE AGAIN...
I have tried re-installing teamviewer and restarting my laptop but still no luck. Even at the start of a new day I get this problem.
Sometimes I can connect but it kicks me out within a few minutes. Other times when I try to connect I get this error.
Still an issue...I appreciate the free version but this is the second time in several months getting Session Timeout within seconds of connecting to a remote PC.
[removed per Community Guidelines] Love the app but support family and friends on a monthly basis..
hi my free account doesn't work. its keep saying commercial use detected
Submitted my reset form and now waiting 2 days for an answer. At least it gives me time to consider alternatives, I suppose.
I am being timed out immediately, what do I do to correct this?
Im not getting any popups on the remote computer or the local one except that the connection timed out, when i try to reconnect it says my license limits the maximum session duration to a partner. im not getting any messages for commercial use either.
im getting the same and tv keeps saying im using it for business use when i only use it for gaming
Having same problem. I have tried to log in over the last two days, about 4 times in total, and each time it works for about 1 min and then I get a timed-out message. I don't see any message regarding suspected commercial use.
Same; Timeout after less than 1 minute. Have been using Team Viewer for more than a year helping family and friends. Never been paid for helping. Personal use only. I assume strongly suspect that this is a software or hardware bug so I just wanted to say that It's happening to me too. Hope you can fix it soon.
I receive a Reply on Facebook Messenger from TeamViewer support. Please note that you need to download the generated PDF, sign it, scan it, and send it back in. Yes I know there are ways to edit/sign online....it's up to you. Go to teamviewer.com/reset
I am getting kicked out or logged out after a minute on TeamViewer and I am unable to access my computer remotely. Is there a reason why this is happening and how can I fix it?
