Teamviewer will no longer connect to host.
VictoriaWhitsett
VictoriaWhitsett Posts: 4 ✭✭
edited July 2021 in General questions
Error message says host not connected to the internet or TeamViewer not open. This is not true. Can anyone help me? I operate the client and I'm 25 miles away from the host. We're both on Mac Big Sur.
    Hello @VictoriaWhitsett,
    I recommend restarting TeamViewer on all impacted devices.
  • VictoriaWhitsett
    I've restarted TeamViewer on all devices multiple times. I also uninstalled and reinstalled TeamViewer on all devices, to no avail.
    Unless you have something new for me to do, I have no choice but to abandon TeamViewer for a more reliable program. That's sad, because it worked magnificently for a year or more before this happened.
    I'm really discouraged and hope you can help me.
    Monica
    We could not reproduce the error on our test devices.
    It is most probably a bug on your device(s).
    But I might have a last resort solution for you...🧚‍♂️
    There is a specific way of uninstalling TeamViewer (the so-called Manual Uninstallation) that really "erases" everything about TeamViewer on your Mac.
    This could reset the settings and solve the issue. It might be worth giving it a try.
    Please find how to proceed here:
    I hope this will fix the issue!
  • VictoriaWhitsett
    Thanks so much. I just used the uninstall button on the Teamviewer from my apps folder, so I believe my uninstall wasn't complete. Will use the steps in this article and give it another try.
    Monica
  • aoga2000
    aoga2000 Posts: 1
    I am experiencing the same issue after upgrading my remote control computer. Did this fix the problem on your Mac?
  • VictoriaWhitsett
    Haven't have time to do a complete uninstall/reinstall. My host computer is 25 miles away from my client. Will get over there on Thursday (7/22) and report back.
