iOS teamviewer not connecting
younso
younso Posts: 5
I have version 10.0.93450 on my work Win 10 computer and can access my account and my home computer from my group of computers. But when I do the same on my iOS with TW version 14.3.2 the group of computers is there but I get an error when trying to connect to my home computer (connection could not be established. Unknown reason").
One thing that I have noticed is that the group on my phone (Mina datorer) has a small cloud symbol next to it. What is this?tw.png
    JeanK Posts: 7,080 Community Manager 🌍
    Hello @younso,
    The empty cloud means, that this particular group has been created by another user and has been shared with you.
    You will find all the information you need in our Knowledge Base article here: Sharing groups
    For your connection problem, please try to restart the TeamViewer service on your home computer.
    -Execute Run, type services.msc and press OK
    -Now find TeamViewer, and restart it by doing a right click.
    Then, restart the TeamViewer application. It should work again.
    Jean Kinzler
  • younso
    younso Posts: 5
    thanks for the suggestions. Unfortunately nothing worked. I have restarted Teamviewer like you suggested, restarted my PC. I can still connect to my home PC from my Win10 PC but not from my iphone.
    Hello @younso,
    You have said earlier that you are running TeamViewer 10 on your Windows 10 computer. The issue might be caused by a compatibility issue, as Windows 10 does not work with older versions.
    Could you please update your computer to the latest TeamViewer version and try again?
    You will find all the information you need in our Knowledge Base article here: Which operating systems are supported?
  • younso
    younso Posts: 5
    you misundertood. The connection from my Win10 machine at work to my home PC (win7) works. It is the connection from my iphone to my home PC that does not work.
    @younso,
    and which TeamViewer version do you have on your home PC?
  • younso
    younso Posts: 5
    10.0.93450
  • younso
    younso Posts: 5
    as I wrote the version I guessed that might be where the problem is. Unfortunately I am also guessing that if I update the version on the Win7 PC I will also need to update the version on my Win10 PC and I cannot do that. My company blocks users from updating and installing prograns on the work PC. So I will proably leave it as it is more important to be able to access the PC at home from work than from my iphone.
    But thanks for you time and effort :).
    @younso,
    I understand... Tricky situation. :-)
    You are welcome.
    Hope to see you soon on the Community again!
  • Qlippoth
    Qlippoth Posts: 2
    edited October 2021
    I get this same error using iOS or the web browser (I use Chrome) when logged into my TeamVeiwer account at login.teamviewer.com.
    All of my computers are all on TeamViewer 12.0.132598 (Latest TV version 12)
    The only method where I can connect to a customer via TeamViewer is my main license activated computer (my work laptop), which I use for most TeamViewer connections to support customers.
    Both iOS and the Chrome App state "Error Reason unknown". Looks like a major bug to me. I can't connect to my customers over the web browser. Which I use when I don't have access to my laptop, which admittedly, is not often, but then it's usually a critical issue, like now at 11 PM on our Independence Day holiday and the customer is law enforcement with a critical situation. Luckily another department in my company has ***information removed as per community guideline***, which I loathe as it has other shortcomings, but it works right now...
    On another machine I receive an error:
    "The remote TeamViewer is running an old version which is out of date.
    Therefore you cannot connect to this version anymore.
    (... etc how to update)"
    Clicking the ok button gives me a "Reason unknown" error.
    ALL of my work machines and customer machines are running the latest TeamViewer 12 version.
    I don't know when this broke, as I haven't needed to connect to a customer machine with another TeamVewier machine, iOS app, or the web client in a long while. But none of them are connecting when they used to do so in the recent past.
  • I am trying to access my home PC from my iphone but it fails to establish connection. What am I missing?
  • Hukabar
    Hukabar Posts: 3
    edited October 2021
    Thanks for the information in this thread. 😊 [removed per Community Guidelines]
