unable to activate privacy screen ( black screen)
Hello everybody
i try to use the privacy feature to make my laptop go black when i connect to it.. but it doesnt work.. drivers get installed properly and correclty shows up in the device manager.. just the screen doesn't go black
how can i fix it?
i have a nvidia gtx 1070 and i'm clueless about how to do that.. i also have an IPS g sync monitor
thank you!
Hi @crushy888
I assume that you have configured the laptop device from your TeamViewer Host as shown here. Alternatively by assigning a specific policy.
How many video cards are installed on your laptop?Let me know
Domenico Langone
MCSD: App Builder
hello
ty for your answer
yes i set up everything as in that thing you posted
i just have one graphic card ,gtx 1070 nvidia( laptop version)
Hi @crushy888
I just saw that you also spoke of a secondary monitor. Do you have a special configuration to handle this second monitor (duplicate monitor or extend monitor) made by operating system (Windows 8-10)?
Domenico Langone
MCSD: App Builder
wait where did i say that? i have no secondary monitor, it's just a laptop with his ips panel
Hi @crushy888
I've read "I also have an IPS g sync monitor" Probably that word ("also") has deceived me. I was pretty sure your laptop was equipped with its built-in monitor...
In any case, I'd suggest trying to uninstall and reinstall the TeamViewer Monitor Driver from your laptop.
Domenico Langone
MCSD: App Builder
oh sorry.. i explained my self wrong.. and ty for helping.. i've been trying install and resintall it many times but it doesn't work
thank you anyway
Hi @crushy888
don't worry!
One test: automatic black screen doesn't work. But what if I set up the black screen during the connection? Screen turn off or remain switch on?
You can find this setting from action panel during connection: if it is set ON (black screen) so swich OFF, then again ON.
What happen?
Let me know.
Domenico Langone
MCSD: App Builder
i tried that too! nothing works..
Hi @crushy888
let's look at TeamViewer logs
Could you include here all the lines that are relevant to the word "blackscren"? We search for phrases related to: tvdesktop::BlackScreen::SignalBlackScreenStateChange
Domenico Langone
MCSD: App Builder
017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::UserInteractionHelper::ChangeServerInput (inputMode 1)
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::InputBlocker::DisableInputAsync(true)
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::UserInteractionHelper::SendInputChangedCmd : inputDisabled:1; blackScreenEnabled: 0
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::BlackScreen::DisableBlackScreen
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::BlackScreentNotifications::Stop - already done
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::BlackScreen::BlackScrState - moving from BSCR_OFF ---> BSCR_INPUT_DISABLED
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::BlackScreen::SignalBlackScreenStateChange (0)
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::BlackScreen::SignalBlackScreenStateChange (0) -- done
2017/05/08 00:28:43.408 12612 12388 D1 tvdesktop::BlackScreen::DisableBlackScreen -- done0 -
there's so much more but i could send you my entire logs if you wanted
Hi @crushy888
if you want yes, but via private mail. REMOVE INITIAL DATA, with specific information of your PC (TV ID, machine data and so on...)
Please note for your privacy: This information is not useful and is obviously related to your privacy.
Only log elements. If you detect IP addresses (unless they are those of TeamViewer servers that are public), delete the value!n.b.: I will try to analyze your log, but it will be difficult to complete the operation in the short run. Can I answer you tomorrow?
Domenico Langone
MCSD: App Builder
sure! i'll send you a pm !
any chance i can send you my logs too?
i got the same issue as OP.
Please see the message here:
https://community.teamviewer.com/t5/TeamViewer-12/Black-screen-not-working-Windows-10/td-p/8940Install NVidia Driver ver. 378.92 (3-20-17) or older. Versions 381.65 - 385.28 do not allow the black screen to work.
