Operating system: Windows
Version: 15.26.4
Release date: 2022-01-25
Hello all,
I am bringing good news for you. 😊
I got the info that this bug has been fixed in the next minor update that will come during the next week.
I will let you know here when the udpate is available.
/JeanK
Tried, but not working. From V13 you only can update to V15.2.2756 directly. In this version the VPN is work fine. If you make another update to V15.26.4, the VPN still not working because the VPN adapter cannot install correctly.
Confirm the VPN issue. For info, if you remove VPN adapter, uninstall the last TeamViewer version, install the 13.0 version, install the vpn adapter, update teamviewer, the VPN works correctly. I don't know why, but it works.
Nicola
Hello @sinesang and @AntonDobschensky,
Thank you for the additional information! 😃🌷
Yes, the new Host design has a dedicated space for the Unattended access at its top part.
When deploying the host with the Easy access settings, it should display the account assignment already configured like in the picture below:
💡 If you don't want the end user to be able to change/manage this setting, you need to make sure you set and applied a policy to prevent it. This policy is called Prevent removing account assignment. You can find more about TeamViewer Policies on the article below:
I hope this information can help! 🍀🙌
Please let me know if you have any further questions. 😊
Carol
i think the newer release, this unattended access is make as standard of the custom design....
I am also having the same problem as sinesang, it appears to have started ~1/23/22, we are trying version 15.25.8, I have not tried any older than that.
Hello @sinesang,
Thank you for your question! 🙌
Mass deployment should be working normally.
However, if you found issues, I would advise you to try create a new Host for the mass deployment.
(The Management Console had major updates implemented to it recently. Therefore, I believe it may be a good idea to try recreate your Host.)
For better assistance, please contact our support team directly. Their contact information you can find here:
I hope this information can help you! 😊🍀
Hello @xmucjy,
Thank you for your message! 😊
For VPN issues, please contact our support team directly. Their contact information you can find here:
Let us know if you have any further questions 🌻😃
Hi , Is there any changes on the Mass deployment matter with easy access? after using the below install command for deploy 15.26.4 , it keep asking to configure unattended access. Tested an older version of MSi 15.21.4.0 - it work normally
Msiexec.exe /i TeamViewer_Host.msi /qn CUSTOMCONFIGID=XXX APITOKEN=XXXX DESKTOPSHORTCUTS=0 SETTINGSFILE="%~dp0option\Teamviewer_Settings.tvopt"
This version CANNOT Install VPN adapter or use VPN connection
See what's new at TeamViewer
