Problem when use api token
I'm having following issue when use api token:
Couldn't obtain updated tokens from MCO for user.... (error code 152)
and the above issue was gone after login into https://teamviewer-iot.com/en/ without renewing the token , and the issue back again after about 2 days... I am wondering does the token have expire time? because I never change my api token
Hi @aryanto
Can you renew the api token on https://teamviewer-iot.com/ and try it out?
Mircea
Tech Support IoT
