Problem when use api token
aryanto
aryanto Posts: 3 ✭✭
I'm having following issue when use api token:
Couldn't obtain updated tokens from MCO for user.... (error code 152)
and the above issue was gone after login into https://teamviewer-iot.com/en/ without renewing the token , and the issue back again after about 2 days... I am wondering does the token have expire time? because I never change my api token
  • mircea_c
    @aryanto
    I guess there were some updates happening on the TV MCO infrastructure and that is why you got the message.
    I tried now and is working.
    The api token, as far I know does not have a expiry date.
    Mircea
    Tech Support IoT
  • aryanto
    aryanto Posts: 3 ✭✭
    @mircea_c
    Thank you for responding. Today I tried, unfortunately the issue still exists
    Here is more detail about the issue.
    Bagus
  • mircea_c
    Hi @aryanto
    Can you renew the api token on https://teamviewer-iot.com/ and try it out?
    Mircea
    Tech Support IoT
  • aryanto
    aryanto Posts: 3 ✭✭
    Hi @mircea_c ,
    It was working okay after I renewed the token but now the same error as above show up again.
    How to fix the issue?
    Bagus
  • mircea_c
    @aryanto
    sorry for the late reply.
    we are checking this issue.
    I will let you know when I have some news.
    Mircea
    Tech Support IoT
