My connection Partner is running an old version and there is no one in front of it?
Riem59
Posts: 1 ✭
I have tried to install all the old versions on my windows(11,12,13 and 14) and I could not connect to my connection partner that shows a message "you are running an old version which is out of date".
I know that I need to check for a new version for my partner and upadte the current version but there is no one in front the computer there.
Is there any other solution here?
Thank you.
Did you find a solution?
Gr
Marc
