Corporate account showing free on PC
Taccard_08318
Taccard_08318 Posts: 2 ✭✭
edited May 2022 in General questions
I have a corporate account that I can log into on the website and iphone application and it shows a corporate account. On My PC it shows as a free account.
I have already tried uninstalling and cleaning the register.
What can I do?
    edited May 2022 Answer ✓
    Hello @Taccard_08318,
    Before starting, as I see that your interface is in French, let me inform you that we have a 100% French-speaking Community:
    French TeamViewer Community
    Just in case you want to get support in French in the future...😇
    What you describe above is typically the scenario when you are using a TeamViewer version that doesn't match the license your company has bought.
    Let me explain to you how it works.
    Since TeamViewer 14, if your company has bought a TeamViewer subscription, you can use any TeamViewer version.
    However, if your company has bought a perpetual license, you must use the TeamViewer version that matches your perpetual license.
    In other words, if your company bought a TeamViewer 11 license ➜ you must use TeamViewer 11, if your company bought a TeamViewer 12 license ➜ you must use TeamViewer 12 and so on...
    You can find the previous TeamViewer versions here:
    💽 Previous TeamViewer versions
    I hope this could help!
    /JeanK
    /JeanK
  • Taccard_08318
    edited May 2022
    JeanK
    Thank you for the quick response. I am actually american but live in France.
    I don't know which type of license we have because the person who handled Teamviewer retired.
    I will try older versions or simply buy a separate license.
    One question. If my license is limited to the version can it work on an iphone application?
    edited May 2022
    @Taccard_08318, you can check the invoice of your license.
    The license type will be indicated.
    EDIT: Yes, it will work on your iPhone. You just have to sign in with your TeamViewer account within the application.
