I have an usb flash drive that I have constantly sent files from. I am now all of a sudden receiving the message above. It only happens when I try to send from the flash drive. I can send from my PC's hard drive no problem. Can anyone help?
@trishsdn I've some news for you. 🙂
This is a know issue in the current version. Our dev team has fixed the problem and will deploy the fix in the next update.
So basically, you'll have to wait for the next release, update your TeamViewer clients to the latest version, and you should be able to transfer the files from your flash drive without any issues.
Have a great day!
/JeanK
Hi @INFOTRADE,
Thank you for reaching out.
Could you please update your devices to v15.35.5 and check if the issue persists?
Problem is back again :(
When TEAMVIEW 32bit update to version 15.34.4, same problem with file transfer (no description could be retrieved when I try to receive file) is present.
I try to send file from my computer and I get another type of message that file I chosen does not exist on path i was chosen!
Same problem on other two computers using same version 32bit 15.34.4....
I try file transfer with the 64bit version instaled on remote computer, send and receive work with no problem!
Saince my needs is most for 32bit version use its a BIG PROBLEM for me and others I guess....
Hi @trishsdn
We are glad that the issue with the file transfer has been solved for you.👍️
Remember to contact us whenever you need it, we are here for you.
Have a nice day!
Valeria
Hello .. I just wanted to post an update to let you know that my file transfer issue has been resolved and is back working normally as it was previously.
Hi!
I tried to transfer a file between computers. I drag the file onto the remote desktop, and it just springs back. I then looked up how to do it, and the article I found says to go to "Extras/Files" in the TeamViewer menu bar. MY menubar only says "Extras". I did enable file sharing on my remote computer. I do not know what else to do to allow me to exchange files between my two computers. Any suggestions?
Many thanks!
(I'm on Version 15.19.4)
@Whitt @Selfish1 @INFOTRADE @David_Georg0pl_Ultra @ttteo123 @DMavidson @BenAtOrangePepper @pellis777
Please see our current statement regarding the file transfer issue below:
Hi Justin,
Yes, I already had TeamViewer_Setup_x64.exe 15.31.5 on my new 64bit WIN11 PC - updating was the first thing I tried. The problem persists (I've just tried it again).
While you're in touch (you've provided email support to me before, assuming you're the same Justin):
I'm finding the screen refresh doesn't work. I use TeamViewer to communicate with a WIN7 PC sitting right next to my WIN11 PC, linked over wifi, but most of the time the Microsoft Windows Media Center screen showing on the WIN7 PC just breaks up, as showing in the .png file copied in here (see the WMC screen sliced vertically near the left side, and other items not cleared after using the Screen Refresh operation (when I try to take a screen shot showing "screen refresh" it only shows the indication that it's tried to clear the screen, copied in further below). Occasioonally it works well.
The PC is top-end gaming spec with 64 GB RAM and AMD Ryzen 9 5900X 12-Core Processor, 3701 Mhz processor (full spec below).
Any advice, please, Justin?
Best regards - Paul
OS Name Microsoft Windows 11 Pro
Version 10.0.22000 Build 22000
Other OS Description Not Available
OS Manufacturer Microsoft Corporation
System Name PAULS-PC
System Manufacturer System manufacturer
System Model System Product Name
System Type x64-based PC
System SKU SKU
Processor AMD Ryzen 9 5900X 12-Core Processor, 3701 Mhz, 12 Core(s), 24 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 0309, 16/08/2021
SMBIOS Version 3.3
Embedded Controller Version 255.255
BIOS Mode UEFI
BaseBoard Manufacturer ASUSTeK COMPUTER INC.
BaseBoard Product ROG STRIX X570-E GAMING WIFI II
BaseBoard Version Rev X.0x
Platform Role Desktop
Secure Boot State On
PCR7 Configuration Elevation Required to View
Windows Directory C:\Windows
System Directory C:\Windows\system32
Boot Device \Device\HarddiskVolume1
Locale United Kingdom
Hardware Abstraction Layer Version = "10.0.22000.778"
Username PAULS-PC\Paul
Time Zone GMT Summer Time
Installed Physical Memory (RAM) 64.0 GB
Total Physical Memory 63.9 GB
Available Physical Memory 48.2 GB
Total Virtual Memory 73.4 GB
Available Virtual Memory 50.1 GB
Page File Space 9.50 GB
Page File C:\pagefile.sys
Kernel DMA Protection Off
Virtualisation-based security Not enabled
Device Encryption Support Elevation Required to View
Hyper-V - VM Monitor Mode Extensions Yes
Hyper-V - Second Level Address Translation Extensions Yes
Hyper-V - Virtualisation Enabled in Firmware No
Hyper-V - Data Execution Protection Yes
Hi @pellis777 and @BenAtOrangePepper,
do you both have the latest TeamViewer version installed? Currently, it is 15.31.5.
If not, please find the download link here: https://www.teamviewer.com/en/download/windows/
Please let me know if this issue persists.
Justin
I got the same error when trying to copy a file from a network (file server) drive on a remote computer to a local disk on my local computer.
After first copying the file to the local disk on the remote computer, it worked.
Looks like the TeamViewer file transfer doesn't handle disks correctly unless they are local.
All of a sudden, I am unable to transfer files to a remote computer.
Error message as follows:
There was an error on the server for the file "drive:\filepath\filename.ext"
Error: The file system reported an error.
Additional information: (2) The system cannot find the file specified.
Files exist at specified location on local computer. I attempted the file transfer from my desktop and laptop .. same problem.
In case it was an AV/Firewall problem, I temporarily disabled both .. no luck.
Any help will be appreciated.
Yes, I've tried this also. I asked a fellow co-worker to try and send me a file from her flash drive on a completely different PC and she received the same message. I believe it is a TViewer issue.
I'd like to know if this is a flash drive or TeamViewer issue.
The best way to find it out is if you could try with a different flash drive and check if it is working as expected.
Can you do this?
Yes, up to date on both sides. As previously mentioned, I can transfer directly from my PC's hard drive with no problems. I only get the message above when trying to send from my flash drive.
Is TeamViewer up-to-date on both sides of the connection?
Just tried that, I received the same error message.
Have you tried to update TeamViewer on both sides of the connection?
Yes i used teamviewer transfer file feature, all this while no problem, but recently this remote computer with id [removed per Community Guidelines] has above error mgs my id is [removed per Community Guidelines] tq
Hello @trishsdn,
Have you tried to rename the file?
Hello @ttteo123,
Great to see you posting for the first time!
Small question, are you using the TeamViewer file transfer feature to export the files?
From one day to the next, I lost the ability to transfer files. It still connects, but when I try to transfer, it responds: 'an error occurred'. My procedure did not change. My phone had an unrelated update (Chrome). I have tried turning off and back on the program, the phone, the desktop and wifi. I uninstalled and reinstalled the program. Why is it no longer working? How do I make it work again? Thank you in advance!
Usualy files on the NAS drive X: , problem is random some work some not. Fresh mirror copy of NAS server is on M: drive (HDD Portable) and it works fine with the same files no problem at all.
Thank you for sharing the screenshot.
Is this happening with all the files, or just with this one?
Hello @INFOTRADE,
Could you please provide us with a screenshot of the error message?
This could help a lot.
I keep geting this message in file transfer, and i can get file....
I never see this message before, I'm using teamview for some 8 years and it's a big problem for me...
Hi All
I hope someone will be able to assist. In Windows 7 if I did a file transfer via Teamviewer and the connections was disconnected. I was able to re-connect and the file transfer would just carry on where it left off.
Since we upgraded to windows 10 this feature is not working. If I transfer a file and get disconnected, I have to restart the file transfer from the beginning again once the connection is re-connected. This is a big problem as we use TV for large file transfers all the time but if I have to restart the transfer every time I loose a connecting it takes for ever to do a transfer.
If anyone has found a work around it would really be appreciated.
I just installed Team Viewer on a new Windows 11 machine. I am running into an issue where although I can transfer files from the new Win11 machine., I cannot transfer files from my laptop to it. I had Team Viewer on my laptop for use on another account and everything works fine (Win7, WIn10 and Win11 machines). When I try to transfer files over to the new Win11 machine, it quickly gives me an "Operation Aborted" error message with no details. Seems like that remote machine is blocking it immediately. Not sure what I need to do to get this to work.
