Team viewer prevents internet connection on pc restart
I have installed team viewer on my pc (windows 10).
Nearly every time my pc restarts, it doesn’t connect to the internet. If I restart the internet adapter a few times, it connects and team viewer also connects. If I uninstall team viewer or if I stop it from starting on pc restart, then there are no internet connectivity issues.
Any idea how to resolve?
  • .Carol.fg.
    .Carol.fg. Posts: 1,073 Moderator
    Hello @Galo190 ,
    Thank you for your post and welcome to the TeamViewer Community!
    I attempted to simulate the issue, but I could not reproduce it...🤔
    • Are you using the latest version of Win 10 with the latest version of TeamViewer (v15.34.4)?
    • Also, when you uninstalled TeamViewer, did you select to remove all settings? You could also try our advanced uninstall.
    I will wait for your feedback to better assist you. 🙋‍♀️
    Carol 👩🏻‍🦰🌷
  • Galo190
    Galo190 Posts: 2 ✭✭
    Hi Carol,
    I just now found out that the connectivity issue still remains even when team viewer is not installed.
    so, it rules out team viewer
    thanks for your help 🙏🏼
  • .Carol.fg.
    Hi @Galo190 , 😃
    Thanks for your feedback and for sharing the resolution of the problem with us! 💯
    It was a pleasure to assist you! You're welcome to ask the Community whenever you have questions.
    Have a great day!
    Best, Carol 👩🏻‍🦰🌷
  • Rui_Sousa
    Rui_Sousa Posts: 3 ✭✭
    I changed TeamViewer settings to allow lan connection and it worked. Try that
