Operating system: Windows
Version: 15.36.9
Release date: 2022-11-28
Was there any information/updates regarding these concerns?
update: i see that it no longer requires login for viewing changelogs. Thank you!
speaking of Changelogs.. why does the site require mandatory login with username / password just to be able to VIEW the changelogs?
Here is the English changelogs/
Where are the historical change logs. I am looking for TeamViewer v6 changelog for all point releases and cannot find them.
It appears that the Connection Report in the Management Console lists Remote Terminal sessions as Session Type Remote Control, will this be updated to display Remote Terminal?
This distinction could be important for compliance issues.
In addition, I'm not seeing anything in Policies that would allow an admin to disable the ability to connect using Remote Terminal. There may be instances where (again due to compliance) we may not want terminal access to a device but are OK with screen control since the user would know someone was remoted in.
Thanks,
