Unattended (no password needed) connection over LAN
virtualG
virtualG Posts: 5 ✭✭
I'm trying to direct connect computers on a home network (router not connected to internet). I succeeded with two computers running TeamViewer (15.37.3) and Windows 10 using the posted directions (https://community.teamviewer.com/English/kb/articles/4618-use-teamviewer-in-lan), but I needed the password displayed on the remote computer to enter at the prompt on the local computer.
Is there a way to direct connect computers over a LAN without needing the remote computer's password? Thanks.
  • virtualG
    Answer ✓
    Solved.
    • Menu -> Extras -> Options -> General -> Network settings -> Incoming LAN connections => accept exclusively
    • Menu -> Extras -> Options -> Security -> Random password... -> Password strength -> Disabled (no random password)
    • Menu -> Extras -> Options -> Advanced -> Show advanced options -> Personal password -> [Protip: Set a strong password]
    • Menu -> Extras -> Options -> Advanced -> Show Advanced options -> Advanced settings... -> Access Control -> Full Access
  • virtualG
    Answer ✓
    Solved.
