Installation fale on Windows 10
I cant install programm version 14. Straight wehen I start installation I see "Error launching installer". What shoukd I do? Just installed one on wifes PC yeasterday without any problems. I hav Kaspersky software, that is only differense
    Hello @Vyacheslav_Kos
    Maybe clearing the registry TeamViewer files could help: How to uninstall TeamViewer on PC
    Then, I recommend you to install the latest version: Download TeamViewer now!
    Cheers,
  • Vyacheslav_Kos
    I had not installed this programme before on this PC. Tried to install the latest version again today- have the same mistake: error launching installer! So it is almost one year I can't use it! Windows was yesterday updated!
  • derek120514
    derek120514 Posts: 1
    once uninstalled before on the same laptop, when reinstall, it failed by saying that error launching installer, what to do ? thanks
