I am using Team Viewer on a Surface Pro 4 and when I connect to a customer the entire desktop appears in a window that is approximately 3" x 3-3/4". How do I make this window larger to fill my screen?
TeamViewer lost the plot with the latest major upgrade of their software. The new UI is desperately unintuitive and requires much more clicks to get to opening a support session with a client. I tried using the new UI for several months and eventually gave up. The plentiful UI bugs that also exist in the new UI only made my return to the classic UI more necessary. If TeamViewer were to remove access to their classic UI tomorrow, I would walk away from the product without any hesitation.
But not being happy with ruining the UI of your product, you have also broken or lost some critical functionality from the product (I am using the macOS client almost all day every day to support my customers), including:
The loss in this critical functionality and reliability is now forcing me to look into alternatives. Unless TeamViewer are able to fix these issues you will only see an increasing number of your loyal customers walking away.
Hi @gregthegeek,
Welcome to our Community and thanks for your feedback.
Despite the new interface, the newest version of TeamViewer Remote operates the same; scaling down is possible for both Windows and macOS, but scaling up isn't possible at the moment.
TeamViewer can only reproduce the partner's screen, mouse, and keyboard. It's not possible to zoom in or to create a virtualization of the partner device.
You could try using an HDMI Dummy Plug with a higher screen resolution. It usually works well with devices that don't have a monitor.
We also would like to invite you to post your idea in our Ideas Hub. We may not guarantee that your idea will be selected by our development teams, but it's the best place to share your thoughts on how TeamViewer can become even better.
Let us know how it goes, and if we can help you any further. 🙋♀️
Best, Carol
Are you kidding me!!?? Why can't we scale up? Why can't it just Zoom-in!! It shouldn't need anything on the client's system, just zoom the image! I can't believe I can't do this. On Mac here, too. Have to reduce my screens each time to do a remote session. I don't want to change my client's resolutions or display settings.
Maybe it's because I got new monitors that I'm running into this? Was this always the issue on older TV versions?
Hi everybody!
Thanks for your questions!
Please know that at the moment it is not possible to scale up on any device.
TeamViewer can only scale to the size provided by the partner's device.
Example: Connecting to a laptop from a large external monitor - the laptop screen size cannot be scaled up past what it provides so that it displays bigger on the larger external screen.
Scaling down is possible for both Windows and macOS.
I hope it helps! 🍀
Why the **bleep** it still doesnt work on mac ?
Any chance we can have it scale to the size of the window it's in? EG, scale up? rather than just down? It doesn't work on Version: 15.37.3 (9191c897b9c) for Mac.
Hi WadeHenderson58,
Thank you for posting.
When you are connecting to the remote device, please go to menu bar "View" and select "Scaled" in Scaling. Then you will get the full screen of the window.
You can refer to following snapshot.
