Teamviewer screen does not refresh unless mouse is moved
Ariaz16
Ariaz16 Posts: 3
edited March 2024 in General questions
My screen seems to not change/refresh at all unless I move the mouse.
I changed my connection to wired from wifi, still does the same thing.Internet speed seems to be fine on both ends so not sure whats causing issue.
Tried both speed and quality optimisation and nothing!
  • Hi.
    I also have this same problem. When I make a change, for example, I open folder by double-clicking the mouse, screen does not refresh, but when I move mouse a little, it refreshes and I see that the folder has opened. It does this on different devices with different connections. No solution to this problem?
  • Thinking of leaving and changing product to another software.
    I find it ridiculous how not a single developer has responded yet. If they make the software surely they could find the fix for it…
    I cant even work properly now due to this
  • Hi, I think I found a workaround which seems to have made the mouse issue stop for now.
    After connecting, on the bar above select view>quality>custom settings
    Colours - Slider set to low
    Quality - Near the middle (greyed out for me)
    Fast video streaming - Adaptive (greyed out for me)
    The two check boxes below that should be clear (no ticks)
    Hope that helps!
  • Extras -> Options -> Remote Control -> Quality -> Custom Settings
    Colors: HIGH
    Quality: Highest speed
    Fast video streaming: Whole screen
  • Same problem here from days....
  • gjon
    gjon Posts: 1
    I've been struggling with this for about 2 months now.
  • irando
    irando Posts: 1
    Also had this issue for several months
  • Pascal24
    Pascal24 Posts: 1
    Same here for weeks. Just adjust "Custom Settings" Quality a bit and refreshing works again.
  • tvale2
    tvale2 Posts: 7
    Same issue but only on some computer … is frustrating, nothing seems to work to resolve
  • balantanis_lakm
    balantanis_lakm Posts: 1
    edited December 2024
    same problem here. for months. **Third Party Product** works fine.
This Week's Leaders
