Teamviewer on very slow and lag
Hello, We are software company in Turkey. We have corporate license for 100 user. Ours support department using teamviewer. During a remote connection, the connection suddenly drops and freezes occur. Can you offer a solution for this?
  • Onurkmikrogrup
    Onurkmikrogrup Posts: 4 ✭✭
    Anyone help me ?
    We are constantly experience slowness and waiting connection screen.
  • monitoramentojcnet
    monitoramentojcnet Posts: 1 Newbie
    me too
  • AlenaC
    AlenaC Posts: 932 Moderator
    Thanks for posting again @Onurkmikrogrup and welcome to our Community @monitoramentojcnet.
    To be able to look for a solution here, we would need more information from you. Many reasons cause slowness during a remote connection. 😅
    Since you mentioned that you have a license our dedicated team can also have a closer look into it. They will be happy to assist. Find the contact information below:
    👉️Customer Support
    Let us know if optimizing the speed does help your support department or you, @monitoramentojcnet .
    Alena
  • Onurkmikrogrup
    Hi, We are experiencing problems even though we have already activated the Optimize speed option.
    But when i request for connection, it waiting for connection almost 10 seconds.
    Some times of the day it works normally, some times it causes problems.
  • aydinli
    aydinli Posts: 1 Newbie
    We are experiencing the same problem. I can access the computer that I cannot connect to from the program via web.teamviewer.com
