Connection Could not Be Established. Reason Unknown.
Hi
i have a error on my teamvier"Reason Unknown" Not sure what to do to fix
Please assist
  • j43
    j43 Posts: 2
    me too
  • bec
    bec Posts: 1
    How do you fix this error message
  • itsouth
    itsouth Posts: 4 ✭✭
    Anyone has a solution?
  • itsouth
    itsouth Posts: 4 ✭✭
    Well I never got a response too - I reinstalled the Host and it worked.
  • AlexFogerty
    AlexFogerty Posts: 32 ✭✭
    I'm seeing it too. It has only started doing this in the past 30 days.
  • AlexFogerty
    As I haven't received a reply from TeamViewer on here I have opened a support ticket with them directly. I will let you guys know what the resolution is when / if I get one.
  • using a vpn is one of the temporary solution i have
  • AlexFogerty
    Teamviewer Support suggested a complete uninstall and reinstall:
    1) Uninstall TeamViewer from the Control Panel > Programs & Features
    2) Delete the TeamViewer folder at below.
    C:\Program Files (x86)\TeamViewer
    %appdata%\Teamviewer
    3) Delete the TeamVewer keys in the Registry:
    HKEY_LOCAL MACHINE -> SOFTWARE -> TeamViewer [32 bit OS]
    HKEY_LOCAL MACHINE -> SOFTWARE -> Wow6432Node -> TeamViewer [64 bit OS]
    HKEY_CURRENT_USER\Software\TeamViewer
    (*Deleting other important keys in registry may cause a serious problem to your computer.)
    4) Download TeamViewer and install
    https://www.teamviewer.com/en/download/
  • using teamviewer in osx
  • mcalin
    mcalin Posts: 1
    Followed the indicated steps and worked (reinstalled TV on the machine where got the error). Thanks to submitter
Howdy, Stranger!
