Hello i've this problem. I've 1 account for private use in 2 pc. But in the 2°pc the free version says me the the "evaluation version END IN 7 DAYS".
How is possible?
Hello
i've fill the form, now i'm wainting a reply
tank you for support
Dear @Loscara88, dear @adelin
Thank you for your posts. We need more information to check your issue.
Please follow this knowledge base article here and fill out the form.
Thank you in advance.
Best regards.Reyhan
redowloading doenst help so customer support looks to be a safe bet
Hello Loscara88,
I think you accidentally did apply the trail version of the premium and that is going to expire! You'll need to reach out to the costumers support (or try to redowload it).
I hope this helps,
