apt update: warnings, errors, "Skipping acquire of configured file"
in Linux only
Just upgraded to TeamViewer 13 on Ubuntu 17.10
Now apt update complains:
W: Skipping acquire of configured file 'main/i18n/Translation-en' as repository 'http://linux.teamviewer.com/deb preview InRelease' doesn't have the component 'main' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'main/i18n/Translation-en_US' as repository 'http://linux.teamviewer.com/deb preview InRelease' doesn't have the component 'main' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'main/dep11/Components-amd64.yml' as repository 'http://linux.teamviewer.com/deb preview InRelease' doesn't have the component 'main' (component misspelt in sources.list?)
W: Skipping acquire of configured file 'main/dep11/icons-64x64.tar' as repository 'http://linux.teamviewer.com/deb preview InRelease' doesn't have the component 'main' (component misspelt in sources.list?)
Can someone look into this?
Thanks,
Colin
3
Thanks for your feedback!
Yes, we know about this. It's mostly a cosmetical issue, and we'll tackle it as time permits.
The repository works fine without these files present.
well, if you stamp a teamviewer.list into /etc/apt/source.list.d/ without asking the $user and this is a no go on debian, than please do the packing of the deb the right way!
And why don't you have a bug/issue tracker where we can fill one (maybe i have overseen it)?
Here is the error massage on debian unstable full-upgraded, 64bit, teanviewer installed via
and its equal wich repository is used.
Same here on Ubuntu 17.10.
Best regards
Volker Holthaus / procar informatik AG
We know about these warnings on recent DEB systems. Older systems don't request them.
The repository works fine without these files. We will fix this cosemtical issue as time permits.
Please, fix it. This warnings really annoying
Looking forward to the fix. Although these warnings may be cosmetic, it takes time to review each one every time users run apt-get update. Thanks.
same problem here. we're waiting for the fix.
I'm not sure I follow this conversation so easily. But are you saying that this error, which I am also getting:
Is this not something I need to worry about? Because I was not receiving these errors for weeks of using it. But now it is coming up everytime I do apt-get update/upgrade.
Daniel,
Now it is throwing errors.
E: Failed to fetch http://linux.teamviewer.com/deb/dists/stable/InRelease 403 Forbidden [IP: 52.85.131.28 80]
E: Failed to fetch http://linux.teamviewer.com/deb/dists/preview/InRelease 403 Forbidden [IP: 52.85.131.28 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
Daniel,
Now it is throwing errors:
I'm getting the following when trying to update tonight:
E: Failed to fetch http://linux.teamviewer.com/deb/dists/stable/InRelease 403 Forbidden [IP: 54.192.2.178 80]
E: The repository 'http://linux.teamviewer.com/deb stable InRelease' is no longer signed.
N: Updating from such a repository can't be done securely, and is therefore disabled by default.
there is a problem with the repository (error 403), i can't update TW anymore. My system is Kubuntu 17.10
other have posted it on Reddit
Repository problem is apparently fixed and working correctly
I have just merged some some similar topics. As you hopefully have noticed, we have fixed the repository meta data a few weeks ago. Please let me know if you still experience any issues.
If you apt update now, you should also have an update available: [Update: 13.0.9865] File Transfer & Chat
Hope you like it! :robothappy:
Daniel
Thank you!
