Hide Startscreen of TV Host 12 in Windows 10 PC
There is a notebook to be serviced remote with TV 12 Host installed under Win 10 Home.
Every time the host is started (= on every user login) the start screen of this software is popping up. The mark "Don't show again" is not saved, and the "hidden"-option in the advanced settings has no consequences.
Have you any idea what to do in this case? Is there any possibility to influencing this by changing the registry?
Thanks for your brain
Bert
Best Answers
Bert Posts: 4
Thanks, Reyhan. Your colleague gave me the following Reg-Entry under
HKEY_LOCAL_MACHINE\SOFTWARE\TeamViewer\DefaultSettings
as DWORD32 named "HostInfoDialog" value 0I will try as soon as I get the computer in my remote hands next time and I will report here.
Best wishes
Bert6 -
Bert Posts: 4
Yes, it works with
as DWORD32 named "HostInfoDialog" value 06 -
Bert Posts: 4
.. and in another Win 10 Home it did not, but:
HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\TeamViewer\DefaultSettings
"HostInfoDialog"=dword:00000000
is working.
5
Hi @Bert
Thank you for your post. We also received your message in our ticketsystem.
My colleague already responded to your request, could you please check your mails.
:smileyhappy:
Reyhan
